Does anyone have any suggestions for revitalising the finish on plated fittings, such as door handles, other than replating, replacing or living with them?
Regards,
Jamie.
Regards,
Jamie.
Revitalising Plated Fittings
Regards, Jamie.
28-12-2018, 07:50 PM
(This post was last modified: 28-12-2018, 07:57 PM by Ruairidh Dunford.)
I use an ultrasonic cleaner - works wonders.
28-12-2018, 08:15 PM
28-12-2018, 08:17 PM
28-12-2018, 08:19 PM
(This post was last modified: 28-12-2018, 08:21 PM by AllAlloyCup.)
I bought a nickel stripping and plating kit
and used it to refurbish instrument rims, handles , screws etc. There’s a thread on this forum , under AllAlloyCup and plating If you need more info just use the search tool above for “Nickel plating” round about Sept 2017 Bill G
28-12-2018, 08:50 PM
Martin - the one I have is big enough to take a crankcase, with heating element etc. If you send me what you want to clean I will do so and send it back to you.
Jamie - I use metal polish and put it back on the car/s, so far, so good.
28-12-2018, 10:31 PM
Bill and Ruairidh,
Thank you both. Jamie.
28-12-2018, 10:38 PM
If you want parts cleaned up Jamie - PM me and I will happily help you too.
28-12-2018, 10:49 PM
Ruairidh,
Thank you.l That is much appreciated. Kind regards, Jamie.
09-01-2019, 11:49 AM
(28-12-2018, 08:50 PM)Ruairidh Dunford Wrote: Martin - the one I have is big enough to take a crankcase, with heating element etc. If you send me what you want to clean I will do so and send it back to you. Ruairidh, What solvent do you use in the ultrasonic cleaner? Andrew |
