Handbrake ratchet for uncoupled brakes
I need the ratchet for an uncoupled handbrake, if anyone has one in reasonable nick (well, a pair actually).
If you're unsure, the uncoupled ones have 11 teeth and each leg of the ratchet is 3.75" between centres of the fixing holes (measured as a straight line)
Thanks
Charles
(23-12-2018, 06:33 PM)Charles P Wrote: I need the ratchet for an uncoupled handbrake, if anyone has one in reasonable nick (well, a pair actually).
Thanks
Charles
I think the suppliers stock these - and from memory the later ones will fit as well.
Part number BK25 at A7 Components, Charles.
Thanks. An email to David Cochrane is needed!
C
