Regulator question
Hello folks
Looking to sort some electrical problems.
Ruby came with almost no electrical cables.
However a few thin wires were still connected to the regulator
Leading me to think it had been run with a 12v system ????
I want to use a 6v system.
The regulator number is CRF 2L
Can anyone advise is this OK for 6v
           Tim
Odd set of numbers for a Lucas reg and or cut-out. Are you sure its not CFR2 which is a common late 1930's cut-out.
Suffolk, UK
1925 Chummy
1934 Box
Tim,
Most cut outs are marked on the case side with either 6V or 12V have a good look have a good look.
Got to an age of 70 without knowing I am dyslexic!!!
Also failing eyesight
Number is CRF 2L
Marked 6v on the moving contact.
What a Dummy !
