30-11-2018, 11:54 PM
I am interested in using a modern diapragm clutch and would be interested to hear comments from those who have gone down that route.
Thanks in anticipation, Gene
Diaphragm clutch
01-12-2018, 09:03 PM
I seen to remember a few of the 750 racers used a modern clutch and saved a huge amount of rotational mass. The flywheel can be vastly lightened
This is also on my list of things to play with. It could give a softer clutch action. The problem is finding a cover plate that will pass over the nose of the gearbox. Any 750 formula racers out there.
02-12-2018, 08:17 PM
(This post was last modified: 02-12-2018, 08:31 PM by Terrytuned.)
You won't find diaphragm clutch that will clear the g/box nose you have to shorten it and make a release bearing adapter see photos.
Terry. flywheel for Renault clutch.
02-12-2018, 09:11 PM
Great pics,
Thanks for posting them. Which renault clutch cover is it ? Its time to find my scrap gearbox parts and play on the lathe. Cheers Richard
02-12-2018, 11:14 PM
(01-12-2018, 09:03 PM)dickie65 Wrote: I seen to remember a few of the 750 racers used a modern clutch and saved a huge amount of rotational mass. The flywheel can be vastly lightened Hi Terry, thanks for photos. Your car, and the component parts thereof are truly a credit to your engineering skills and dedication. All the best Gene
03-12-2018, 12:44 AM
The clutch kit is for a Renault 4 and early 5 with 845cc engine. QH part no QKT 136 AF used this kit for the last 10yrs it makes a great
hillclimb/sprint/race clutch but is a bit to switchy for the road as you are operating it directly, and needs careful setting up but completely reliable for 5000rpm drop the clutch starts.
03-12-2018, 10:20 AM
(03-12-2018, 12:44 AM)Terrytuned Wrote: The clutch kit is for a Renault 4 and early 5 with 845cc engine. QH part no QKT 136 AF used this kit for the last 10yrs it makes a great So what's the total weight of that flywheel and clutch assembly Terry? Thanks Charles
03-12-2018, 11:05 AM
Weight of clutch flywheel assy: about ten and a half lbs, less than half the weight of a std assy.
Terry.
03-12-2018, 02:24 PM
03-12-2018, 03:43 PM
For anyone who wants to try a diaphragm clutch I am posting drawings using the Renault clutch kit there may be a more modern cover
available but I have only used the Renault kit. Terry. |
