Presumably the guy that fitted it thought the timing gears needed more oil, or he'd had a bad experience
30-11-2018, 07:34 PM
(This post was last modified: 30-11-2018, 07:35 PM by Ruairidh Dunford.)
Rob Beck has made a similar mod from the end plug to feed the intermediary and vernier drive gears on Mag. engines.
Really lovely grommit on the dynamo wiring.
Don't change it - it is wonderfully old!!!
I love the copper wire cable tie! Presumably fitted before plasic variety.
It's all great and should be left for posterity!
30-11-2018, 08:37 PM
(This post was last modified: 30-11-2018, 08:38 PM by Biddlecombe.)
Can I ask though, is the tap designed to be a permenant feed or to be turned on from time to time?
30-11-2018, 09:02 PM
(This post was last modified: 01-12-2018, 10:19 AM by Bob Culver.)
I saw this on a local 40 years ago. If can tolerate the pressure tap off, and not flood dynamo innards, would seem a good idea.
All the good books recommend generous lubrication of cross gears. It would quiten, and reduce the iron dust in engine.
many cars with 12v etc are now extracting far more watts from the dynamo than originally and it all requires power to drive.
Nevertheless life of original gears is 100,000 plus. Vital that the original feed is functional.
Cars look so much more original with exposed horizontal plug connectors. My Seven used to slog into horizontal rain and salt spray in notorious Wellinton winds and never missed a beat.
