17-10-2018, 10:22 AM
I've been struggling getting the steering wheel off my traction engine.
Its mounted on a tapered square and was pulled onto the taper with a 3/4 whit nut. So it was pretty tight.
The wheel is cast iron too, so I was keen not to break it.
Its a difficult thing to use a puller on. After a bit of thought it dawned on me that a modified brake drum would be ideal.
I also had to grind the wheel mounting lugs off to. But I was successfull.
