Starter Grommet
Does anyone have a suggestion for a grommet carrying the cable through the casting on a bacon slicer starter?
It looks a lot like the black one on old electric irons as it has an extended body.
I have made a wooden pattern but lack the skills to cast one in rubber.
J.W
I'm not sure whether the grommet in question is BD94 or 126.
(05-10-2018, 07:56 PM)Chris Garner Wrote: I'm not sure whether the grommet in question is BD94 or 126.
Chris - I think it must be BD 94 as it refers to starter switch cables and says 3. (July 28 parts list page 17)
I suppose the other 2 would be for the 'progress' of the cables from battery to starter.
Perhaps thinking of getting some made but assume someone would want to make a lot and demand would be for say 10 at the most!
John W
Chris, Could you make the grommet from a piece of rubber hose and an "0" ring?
What about one of these and just cut the end off?
If it is BD94 you require this is looks quite close:-
https://www.ebay.co.uk/itm/15-Pcs-Rubber...0505.m3226
It is for a hole diameter of 14 mm as opposed to 17/32" (13.5 mm). If it doesn't fit as is you should be able to cut a small bit out and re-glue it.
If you search for strain relief or sleeve grommet or cable sleeve you may find other possibilities.
Edit - Just noticed the long delivery on the above item. This one for a 13mm hole may be better:-
https://www.ebay.co.uk/itm/Rubber-Strain...5Hmr1fP57A
