chummy STILL not running right!
good evening gents
determined to get chummy PX6609 running right again!
Symptoms: has to be properly flooded to even think of starting.
Pulls well in first and second with some hesitation... gets into top really flat....... running an original brass zenith. Jets are 70 in the one under the long tube you can adjust a screw above from the outside.... and the other 75 which I couldn't get out to clean... jet key ordered..... do these sound write
I think mag is ok I tried it one tooth either way on te connector and it was worse...
gratefullyefuly received!!!
best
P
