20-09-2018, 10:56 AM
(This post was last modified: 20-09-2018, 10:57 AM by Austin in the Shed.
Edit Reason: add content
What work have you done to the engine ?
If its a coil engine take the rectangular cover off the dynamo housing (Briefly) when its running to see if there is an adequate oil supply to the gears.
If you are using different timing gears/mismatched gears they could be noisy,but if they are cast iron (original gears) they will get more quiet when they bed together.If you have a high lift cam they will run noisier.
It could be end float on the camshaft. That is also noisy.
I agree with Austin above. Check the camshaft end float easy enough to do. Some people like Hedd Jones who subscribes to this forum can get the camshaft in and out whilst the block and crankcase are still bolted together.
John Mason
If your camshaft has been reground you need to carefully check that the followers are staying in contact with the base circle, two things can happen. If you have not shortened the follower guides the tappet lock nut will prevent the follower remaining in contact with the base circle. And/or, it the cam has been reground with a narrow wheel the follower foot might be too wide and riding on the shoulder formed when reground rather than the base circle.
Most of the good pairs of gears have been bought by people who have had the Accuspark Dynomator ruin their gears.
