  • 1 Vote(s) - 5 Average
Radiator Grille patterns
What is the correct pattern of core for a 1930 Seven?
I need to get Adam's radiator re-cored as it is "a bit leaky" & would like to use the correct pattern of core if it is still available.
Your comments are welcome.
Thanks,
M
I think you will find that Serck A film is the correct pattern for the majority of sevens, although it appears some were fitted with honey comb cores.
Thank you.
(18-09-2018, 10:57 AM)mk1-mark Wrote: What is the correct pattern of core for a 1930 Seven?
Thanks,
M
Yes still available from vintage radiator company
