My 1932 RN saloon engine mountings are bolted directly to the chassis (without rubber pads). When I first fitted the engine and subsequently, I bolt the rear mountings of the engine tight to the chassis, the front mountings I leave them loose (ie: finger tight and then one turn less). This I was told minimises stress from the crankcase as the chassis twists (under duress).
What does the team think.
Bob
I bolt mine down with 4 bolts as Austin intended.....
Yes there is a gap under the front offside and rear nearside feet of about 1/8". I've yet to find a non rubber mount crankcase where the feet aren't seriously fretted such that the four feet are not all in the same plane.
The offside rear should not be flexible, it has to take the thrust of your foot on the clutch pedal.
The other 3 can have a degree of play. Rigidly bolting all 4 to a standard frame can result in all kinds of engine bother in a car that's driven with enthusiasm, but possibly is o.k. on modern roads for gentle use.
Thanks Roger, I couldn't remember why opted for FNS and ROS configuration.
