Having cleaned umpteen years of grime from my gearbox (4 speed) I find these numbers on the top:
2 SYN 530 ....S
can someone tell me from whence it came!
And the ending S, for sports.
David,
Is there an " S " stamped to the rear of the gearbox casing? If so, and the gearbox hasn't been messed with it, would indicate it contains Nippy ratio gears.
I had always understood a 2SYN suffix indicated Syncro on 2 gears. i.e top and third. A 3SYN suffix indicated Syncro on 3 gears. 2ND third and top
As I recall the car had other Nippy parts fitted so I anticipate you will find its a Nippy gearbox
Wasn't the gearbox described in the sales literature as a "Double Top" gearbox ?
