Thank you both, I will update as things progress.
I hadn't realised any Bantams were built with right hand drive.
This van was for the NZ market, we drive on the left same as the UK, however I could not tell you how many cars and vans were built RHD, perhaps Ivan G can give us some insight?
It looks like a good solid vehicle. Is it complete?
Peter.
Yes Peter it is a good solid vehicle, and it should be more or less complete, however the owner has passed away and the parts are scattered around a large shed containing a lot of other cars and parts so I am still searching for some of it! The object of the exercise I have been tasked with is to locate everything then resemble the Van so it can be sold, I will probably not complete the restoration simply put it into a state where someone else can and where we know what is missing.
