clutch pedal
Hi people
Me again could anyone help with specifications of 1936 Ruby clutch pedal.
Or the length of the pedal would be useful.
          Tim
It is to the same design as the brake pedal, but shorter with an overall length of approximately 125mm - face of pedal to tip of shaft. Secured to the pedal lever with a bolt.
Many thanks Gary.
I guess the 125mm is mesured along the curve?
I was was going to use the same arc as the brake.
Tim
(26-07-2018, 08:32 PM)Tiger Wrote: Many thanks Gary.
          Tim
Try to get a secondhand one, but a brake pedal should do the job, you will need to form a groove in the shaft for the bolt to engage with. The 125mm distance is the overall, any shorter than that and you will have insufficient travel before it hits the floor, any longer is fine.
