Camshafts
Hi All,
I would like to know the Factory camshaft specs for a supercharged Engine.
(ie) Opening & closing Times
PS not the local pub
Cheers Colin
NZ
Hard to believe no one has the Factory Specs
Colin I have them recorded as; Inlet open TDC, 220 deg duration on inlet, 240 deg on exhaust, 15 deg overlap and lift .320. these are not my measurements and I question the inlet duration but they may form a starting point for discussion.
