I've recently purchased a 1938 Ruby and I'm in the process of making it suitable to use. Part of this is to make the seats a half decent place to sit..... so I have treated them with Neatsfoot Oil which is what my research led me to and seems to have done the job, but this has now led me to a new issue:- the seats are now oily (obviously!), and they'll damage clothes if sat on.
So, whats the consensus for dealing with this new issue?
1. Keep going over them with a dry cloth/rag until I've dired them out a bit?
2. Leave them to air and eventually they'll settle (sit on cover in the meantime).
3. Treat them with something else to seal them?
4. something else?!
Thanks in advance,
Ray
I think that you will have to wait for the Neatsfoot oil to dry naturally but give it a little help with a dry cloth. On a very old leather sofa, I use a hide cream once a year, not too much, polish and no messy clothes.
I would not try sealing the leather even when dry, although I do use Scotchgard on Nubuck shoes.
If you want to use the car before the leather is dry and not spoil your clothes, put a sheet/dustcover on the seats.
You could always read up on car leather care products.
My saddler friend advises the use of olive oil.
When I have used it on old seats I thought were fit only for the bin the leather has revived to the point where, despite appearances, it was usable, and the oil had soaked in and gone.
The leather should soak up the oil, these far gone seats took half a dozen brushed on coats over a week or two.
Simon
Are we talking original Austin seat leather? Or has the car been re-upholstered?
A lot of modern upholstery leather is in fact 'plastic' coated (and general advice as far as I can tell is not to treat it with anything).
Thanks all for the suggestions. I think the first approach will be to keep buffing the seats without giving them any other coating or treatment and hope that very warm weather we're having at the moment will do something to dry them out a bit (ironic really as I've done everything I can to undo their extreme dryness in the first place!).
If that doesn't get a useable result I'll look in a bit more detail at the other coatings you've suggested.
Ray
