Fuel outlet size from tank
I have just bought a very nice front mounted petrol tank for my Ulster Special build.
The outlet is 1/8 BSP. I understand most are 1/4 BSP. I wondered whether the smaller diameter of the inner diameter could limit the fuel flow?
It appears to be slightly smaller than the end of the standard solder nipple that goes with 1/4 BSP.
Am I worrying unnecessarily?
It's way bigger than the 90 jet hole in your SU carb. I wouldn't worry
(22-06-2018, 02:08 PM)PaulS Wrote: I have just bought a very nice front mounted petrol tank for my Ulster Special build.
Mine's like that and it is not a problem!
Robert Leigh
(22-06-2018, 03:21 PM)CharlesĀ P Wrote: It's way bigger than the 90 jet hole in your SU carb. I wouldn't worry
Thanks, very good point, I feel a bit daft for asking now.
