oil lip seal CR 9934
I have 2 new boxed oil lip seals labeled 9934  CR services (an SKF company). It is 1 X 1.624 X 0.25 inch (25.4mm X 41.25mm X6.35mm)  I cant remember where I got them from or what they are for........however I suspect they may be for the back axle internal seals to replace the half shaft felt seals.  Can anyone shed any light in this?  I have finished doing an axle total refurbish and seem to remember the lip seals I used were a slightly different size  (1938/39 heavy axle.) so what were these for??? maybe the earlier axle casing?
Dennis
