Rist Horn Threads
Anyone know what thread the terminal posts on a 6V Rist horn are? 3BA perhaps?
They are a shade bigger than the 4BA screws which hold the unit together.
(23-05-2018, 07:57 PM)Chris KC Wrote: Anyone know what thread the terminal posts on a 6V Rist horn are? 3BA perhaps?
Good morning Chris, I've just tried two horns and the thread on them is 2BA.
Stuart
Are you sure, I thought they were coarser 5/32 whit from memory??
(24-05-2018, 08:45 AM)Ian Williams Wrote: Are you sure, I thought they were coarser 5/32 whit from memory??
Not sure at all Ian, wild guess based on approx dia over threads ~4mm; so 5/32BSW sounds plausible.
They are a bit manky so I want to clean them up, would be good to do it with the right die...
Hello Ian, I too thought they were courser than BA but a 2BA nut fitted both horns perfectly.
Stuart
Sorry Stuart (& thanks) - somehow I missed your reply earlier.
I wonder if more than one size was used? I'm pretty sure I offered up 2BA last night but it looked way too big; and that would be 4.5mm across the threads (might be more worn than I thought). I'll have to check again tonight, stuck in the office right now!
Interesting Stuart, I have two genuine Rist horn's here and both are not 2BA, in fact a 2BA nut goes straight over the studs 5/32 BSW is correct for mine so perhaps there was a variation.
5/32x32tpi on mine.
Geoff - Compressed air cooler completed.
(24-05-2018, 12:55 PM)Geoff Halstead Wrote: 5/32x32tpi on mine.
This may help (or confuse....)
Across flats a 2BA nut should be 0.324". 1/8BSW 0.338" . (M5 nut  is 8mm ...0.315")
I think a No 6 UNC/F is 0.313 (5/16"A/Flats)
(24-05-2018, 10:55 AM)Ian Williams Wrote: Interesting Stuart, I have two genuine Rist horn's here and both are not 2BA, in fact a 2BA nut goes straight over the studs 5/32 BSW is correct for mine so perhaps there was a variation.
Hi Ian, just tried a third Rist's horn and it is as you suggest 5/32x32tpi BSW, so there is (was) variation.
5/32 Whit is of course the same size as the original Meccano thread.
Stuart
