droplinks on standard SWB suspension
Is there any SWB suspension advantage in:
1. adding longer rear alloy links? (than the standard shortest ones)
2. removing one of the front droplinks to enable a direct axle connection?
i.e. for modern road driving
I only ask as these things are done for sports, and I'm not sure if the advantages would be the same.
thanks JonE
Jon, I assume you are referring to the shock absorber links front and rear.
IMHO,
1. Probably not unless the shock absorber arm is going to hit something on full bump.
2. I consider some form of front axle location desirable and that would be one way to do it, so yes. It's a bit crude but I admit to having done the same myself for half a century.
Regards,
Stuart
(06-05-2018, 02:13 PM)JonE Wrote: Is there any SWB suspension advantage in:
thanks JonE
The long links are for 'low frame' cars, Rubies and derivatives. I think they would be a disadvantage on the earlier high frame cars, because the geometry would give slightly less angular travel on the shock absorber than the standard link. I do run my Chummy with a solid (rubber bushed) connection to the axle on one side.
Robert Leigh
thanks both. I'll proceed with front (saves a few grammes too!) and discard thoughts on back.
