14-04-2018, 02:39 PM
1931 RN Saloon, when driving at 30mph, oil pressure is only registering at 2. On warm start up she pressurises within a second or so and on cold start up instant pressure and fills the clock.
I am running on SAE30 and recently cleaned the sump gauze, I am a little concerned that the 2PSI drops to nothing when you stop at traffic lights to an idle. if you touch the accelerator oil pressure will increase between 2 and 4 depending on how high you rev. one other apparent point this car has had for years, when you switch off after a 5-6 mile drive and immediately engage the starting handle it is ever so tight to turn over for the first revolution, if you continue on past 1 revolution she is quite free as normal and never does it when cold or partially warm. The engine is not over heating nor is fan belt slipping and had a recent head off de-coke. I would appreciate if anyone could put my mind at ease on these matters?
