24-03-2018, 02:19 PM
Hi,
Please could someone describe the correct radiator mounting for the radiator core to the pressed metal mountings. I am talking about the painted radiator cowl models (Ruby, Opal etc).
My radiator has two studs at the base that pass through holes in the supporting plates. Should there be a rubber mounting (similar to engine mounts) that support the radiator to prevent vibration?
Many thanks!
Matt
Many thanks!
Matt
