01-05-2018, 10:56 PM
Does anyone know what this item is?
Unidentified Part III
01-05-2018, 11:29 PM
02-05-2018, 12:49 AM
(01-05-2018, 11:29 PM)Tony Press Wrote:(01-05-2018, 10:56 PM)CaptainBob Wrote: Does anyone know what this item is? Whilst Ian is correct, when he says Early Sevens. the oil button shown is for a late-'28, '29, 30' etc - whereas the really Early Sevens (1923 to late '28) did not have a flange either side of the button, the bezel was circular. Cheers, Bill
02-05-2018, 04:24 AM
And just to add a little more, the black button popped out a little when you had "some" oil pressure.
02-05-2018, 07:07 AM
out of interest, is this later one less prone to the 'oil in your lap' thing which seems to be accounted in 750 Companion/tales of yore etc?
02-05-2018, 07:29 AM
Not in my experience.
They can be repaired using the plastic wrapping used for bacon however - true!
02-05-2018, 11:51 AM
The "official" material for the diaphragm was not bacon wrappers, but pig's bladder - so I suppose there is a connection there somewhere!
I have repaired mine successfully (no leak after 6,000 miles) using a few layers of thick(ish) poly bag.
Rick
In deepest Norfolk
03-05-2018, 01:03 AM
(02-05-2018, 11:51 AM)Rick F Wrote: The "official" material for the diaphragm was not bacon wrappers, but pig's bladder - so I suppose there is a connection there somewhere!Just to clear up my perhaps-confusing above post (for the pedants) - the late '28 cars introduced the '29 models, then all of 1929, then up to mid 1930 (from there the button type were replaced by a dial). Forget the "etc". Cheers, Bill in Oz
03-05-2018, 12:41 PM
And a further bit of possibly useful information: the bodies of the two types are identical and the bezels are interchangeable - they screw on and off.
Rick
In deepest Norfolk |
