15-08-2023, 11:31 AM
(This post was last modified: 15-08-2023, 11:32 AM by Steve Jones.)
The coast became clear at 10.45 today so I've been able to come up with a proper answer!
Bare chassis but without the brake cross shaft fitted weighed in at 25Kg.
Next, see if you can get away with cleaning a crankcase in the dishwasher. I’m surprised it’s that light actually.
Easiest way, Steve is to pick it up and then get on the scales. Take the measurement and then get off, put it down and weigh just yourself.
That's okay as long as the combined weight doesn't exceed the limit of the bathroom scales!
I've often thought that a pair of rear springs must weigh as much as the chassis frame.
