04-08-2023, 05:05 PM
Looking for a rare "lift the dot"
04-08-2023, 05:32 PM
Martrim used to supply them but they do not seem to be listed now but a company called Bresco.com list them in packs of six.
04-08-2023, 05:55 PM
(This post was last modified: 04-08-2023, 10:57 PM by Tony Griffiths.)
Thank you for that link. Some interesting variations are available. https://www.bresco.com/cgi-bin/ss000001....TION=Go%21
I needed some to go through the rubber blocks on the hood supports, but they have to be at least 20 mm long. Mick Hobday suggested taking one of the two-pronged types, cutting off the prongs and soldering in a length of screwed rod. The suggestion worked perfectly. It's also possible to take a double-length type with the longer 2BD thread, cut that off and drill and tap it to take a length of 3/16 BSF studding.
04-08-2023, 06:01 PM
I think this is just a single height one, but these are the people to talk to for fasteners.
https://www.jclarkemarine.com/collection...h-to-cloth
Suffolk, UK
1925 Chummy 1934 Box
04-08-2023, 06:15 PM
https://www.vintagecarparts.co.uk/produc...oth-stud-1
Best I could do. It's not cheap! Regards, Stuart
04-08-2023, 07:26 PM
I have a few old stock, salvage from a trimmer's shop, I've never found a use for them myself. I have the slotted backplates as well. Let me know what you want, all very cheap!
06-08-2023, 11:15 AM
Thanks for all the help!
Stuart - I searched high & low but didn't find that one - well done! I reckon £6.18 for a pack of 10 is OK, though the postage and the fact that I only need two, does end up with them being over £5 each! So, Mick - I'll PM you and buy the ones you have! Cheers all! James |
