16-07-2023, 11:07 PM
(This post was last modified: 16-07-2023, 11:24 PM by Marcus Ling.)
Hi,
Does anyone know if the spring pins for use with Hartford dampers are available ? Ive search on the usual suppliers but no luck.
They are different to the Austin ones, the top one in the photo is Austin while the bottom 2 are for Hartfords apparently.
Many Thanks
Marcus
Supplementary question Mr Speaker,
I'm making some new Hartford front and rear dampers and don't know what one of the gaps is between the link plates shown in the attached photo.
I know that the gap where the bolt is is 7/8", both plates are joggled but I don't know what the gap should be where they have the tube welded in which holds the bush that goes on the spring pins. If anyone has one handy that they could measure I will be grateful.
Marcus
Many Thanks
Marcus
Marcus
