13-06-2023, 01:35 PM
(13-06-2023, 10:35 AM)Colin Morgan Wrote: The brake rod for the July '38 onwards rear brakes passes close to the axle casing on the driver's side, on its way to the swivelling 'tree' mounted on the casing which activates the rods that go to each side. I think that is why the filler was moved.
Ah! That makes sense for rod actuated brakes. However the diff I'm working on is dated August 1937.
