07-06-2023, 12:49 PM
(This post was last modified: 07-06-2023, 04:46 PM by Colin Morgan.)
A Rosengart has appeared on ebay. Interesting to compare with the 1936 Ruby?
(Don't know the seller, usual disclaimers.)
The Rosengart gained semi-elliptic rear springs in, I think, 1933, but retained the scuttle-tank and three-speed gearbox throughout production. Both these are 1936 cars, so the specification is correct.
What if you were to add an American Austin/Bantam into the mix?
With no running boards, and easy-clean wheels, the saloon looks more like a big seven. The idea of the bigger boot hung onto a Ruby might be good, but hanging the spare wheel on the outside looks a step too far.
Did the Rosengart have a bigger engine? The Ruby is low enough power to weight without hanging on a boot and the resultant luggage.
09-06-2023, 01:36 PM
(This post was last modified: 09-06-2023, 01:38 PM by Colin Morgan.)
Interesting to see the change to the rear suspension repeated on the American car. Lord Austin was perhaps keen to keep the Seven as originally designed, whereas others were ready to make greater changes to the chassis? Staying with the original rear suspension kept everything simpler - but, as anyone who has travelled in a Ruby will know, it did allow significant roll - especially these days on roundabouts at anything above 15mph. However, as this is a defining characteristic of the car, I cannot imagine a Ruby without it.
