20-04-2018, 09:34 PM
It is a long time since I changed a broken half shaft....found a new one in a Garage in Farnborough opposite the RAE up in their rafters. It cost about 20/6d as far as I recall in 1957 with it's original packing & price tag!! I bet it costs a bit more now.
Well I need to do it again (different car, same problem). The o/s hub is distinctly loose & appears unconnected to anything!
I will have to make/borrow a half shaft/brakedrum tool, I have a stout 3/4BSW spanner, so I should be able to get it apart, but I cannot remember if the shaft bits will simply pull out of the diff, or do I have to split the diff?
I am not looking forward to seeing the state of the hub taper etc. I will know the half shaft length when I get it apart
I am not sure of the axle type (three I think), It has stamped on the diff "49541 and then what looks like a 9 above
the 1...the numberer ran out of space!) Any code-brakers with ideas?
The axle measures about 36" between backplates (Morris Minor ones for the hydraulic brakes )
