Car type:
Has anyone got a useable ball change 3 speed top please surplus to requirements?
Indeed, does anyone know if an earlier one will fit in its place?
thanks
Car type:
ah, Tony, that is very interesting. Have you or others got experience of what the feel of the earlier and later top are like in comparison? I believe the later one is a longer stick, but does it fulfil any great purpose or evolution?
I know it sounds a bit naff, but I quite the look of the earlier top...
Car type:
all very interesting. I am imagining a Stadium extension is a period accessory? It sounds like what I need to do first is bend this semi-broken one around and see what happens in use. (It sounds like unless you are an Italian, Alfa Romeo-fitting long-arm-short-leg sort of person, the short lever might be something to pass on...)
