22-03-2023, 08:48 PM
(This post was last modified: 22-03-2023, 08:48 PM by Matt_Harnden.)
Old (modern) Voltage Regulator Identification
22-03-2023, 09:11 PM
22-03-2023, 09:52 PM
Yes, a "JG 12 Volt Electronic Regulator" from the early 1980's.
But is it a positive or a negative type? Both were available. ![]()
22-03-2023, 10:09 PM
The first photo from Matt has an 'N' so presumable negative earth.
22-03-2023, 10:21 PM
Absolutely blooming fantastic. You‘ve made my day! THANK YOU
23-03-2023, 12:05 AM
Make sure that you earth the case, I made an error when I refitted mine on my timber bodied marine special. No output until I gave it an earth return.
23-03-2023, 07:28 AM
(This post was last modified: 23-03-2023, 07:39 AM by Henry Harris.)
24-03-2023, 12:21 PM
Treat it with care because they are no longer available.
