15-04-2018, 11:11 AM
Hi all,
I am replacing the choke spring on my Zenith 26VA carburettor.
To remove the broken spring it appears that the choke operating lever and (throttle ?) cam will need to be separated. They are I assume a tight push fit but I am fearful of damaging one, other or both.
How is the best way to tackle this?
Roger
For choke read air strangler or air shutter if you prefer!
Roger
