Petrol tank BSP fittings
Further to my new petrol tank. I am left with what appears to be a parallel 1/4 BSP female thread (photo) - the old tank had a 1/4 BSP parallel "male" fitting (photo) the pipe to the engine has a flared end and threaded attachment. (photo). I assume that this is a standard A7 fitting to a rear tank.
Obviously I need to convert the new female fitting to a male end. Is there a special end on the adapter I need OR will the flared pipe fit to any 1/4 BSP fitting?
1/4" BSP nipple
https://www.ebay.co.uk/itm/202015556990?hash=item2f0910c57e:g:3nUAAOSwJRld6L6o&amdata=enc%3AAQAHAAAA8PQuvOCfNAIPIV%2BnMGEskH%2BZmcfqWuE0D8H83GAFFFtohZh5qRHXcP1mISzgGNzFu0O7WlFJmmXN%2FmE5W%2F9PUC31UDviRrD3Oaju8Qt5gRYuC2coXjLBh1wqk9fU5q7Ttr6S8Uid7X19QoYZIHv8fyccKCl6DW%2FZ2%2Bpu7pPhXJ4eK9ehtmoZdfyZs4VQw8iW02wXAtTzUeT4n0OlyIkdG0pHNe8FRdUnuebL3NEiKwbGxzxmhgI7MwOfmaAzBT36Cpc5qR7BsT1%2BBBtKRQpvyJLJsfKGLDGAm3br%2FMCLOPJ9U3tesYhvnhr4ZMDck0QZwg%3D%3D%7Ctkp%3ABFBM5Ne_6tVh
and use one of these Dowty washers between the nipple and the tank.
https://www.ebay.co.uk/itm/353856013351?hash=item5263764427:g:VjoAAOSwJ1dh4E1H&amdata=enc%3AAQAHAAAA4JK9xeV1M0dyvkACc3LH6d3Lt4vS99RLLh%2B60egN9uVrnSjNIf8Mc6oLS4lSUg6Pp7eUGLEqBcVvhGrcKA0RH%2FlHf9bwEy%2FmjdsLj6wKGOLqV%2FRlAlGkD8jDBZNCVYoJ%2FNN92VzQhdoZe3nCzme63IAZNOeDO%2Ffj1TXLm2Aztsl2gB7NF50eMSWPKR1wTjitNSBbly47%2BgLJnVaeQuPOTcc8OCoc4EIxo5mPo0N%2BwmbvCWpE1eScvJ5vzpUHe7c5IHTm03YLoq7%2F4iteNBzUbofALl98Ed9d3QQoKCoIYQ67%7Ctkp%3ABFBMjvrV6tVh
Thank you Stuart. I can see that will do the job nicely. I will get them ordered.
Dave Richardson
