Nice to see such attention to detail. It should pay dividends.
Car type: 1932 RN saloon
Hedd,
I use the rad arm spring as a spacer,ie it’s coil bound!
The axle even needed twisting to get it all correct Dennis.
Using a modified domestic tap valve face cutter gets away with fannying about with grinding paste. Gets it flatter too.
That said, Ive driven a few cars where the king pins were atrocious and never had the problem I describe.
I will report back once I've had another look.
I believe fathers is a very old unbranded cutter. I have it now and its in a biscuit tin!
