Car type: Ruby mk 2
Hello People
I am considering converting my original sidelights to use as indicators.
I want to use the 6 volt system.
Some thoughts
Painting higher output bulbs
Painting the existing light glass and use clear bulbs
Can I purchase a yellow LED ?
Idea’s and thought appreciated
Regards
Tim
Hi Tim
Like me you seem to be an early riser!
I’ve tried all of your proposals and the best is the yellow LEDs. I believe you can get combined indicator side lights from certain suppliers but that would mean extra wiring and fitting a new bulb holder.
Personally I found painting bulbs and clear lenses not a success. I have converted a pair of Lucas T21 lights by casting new plastic lenses dyed yellow and they are acceptable.
Out of interest where will your sidelights be?
Hi
I use sidelights combined with headlights, which leaves the wing mounted indicator bodies free for use as front indicators. At the rear I have a couple of period indicator bodies mounted on the bumper.
The first version used 6 volt 18 watt "small globe" bulbs, combined with orange "gel" film of the sort sold for theatrical lighting. It was necessary to use 3 or 4 layers of the film to get a deep enough colour. The problem is that bulbs of this type tend to prematurely blacken inside the envelope, and lose light output. I guess this is due to the heat buildup in a small space.
The second version uses orange/yellow 6V LEDs and is far more satisfactory. They are brighter and the flashing effect is "crisper" and more noticeable.
Some electronic flashers get upset if you have unsuppressed plug leads.
You will need an electronic flasher unit to run LED indicators. They are available in both 6v and 12v versions. I bought mine through classic dynamo regulators, along with the orange LED bulbs.
Car type: Ruby mk 2
Many thanks Gents for your comprehensive replies.
Howard I usually make tea early and check the Austin web site.
I shall follow John’s lead and use the existing front sidelights as indicators.
The rear will be bumper mounted small black torpedo shaped
For all I will try LE diodes
PS Hoping to retain the semaphores ?
I have just fitted "flashicator" bulbs to my neighbour's car's semaphores.
We are impressed and pleased with the results.
They are much more visible than I was expecting them to be.
Car type: Ruby mk 2
Thanks for the diagrams
I was thinking for putting a flasher unit in the live feed before the steering wheel indicator switch ?
