Yes, I forgot to mention the door drop, that is always worth checking out because sometimes it can be a sod to fix.
The black 34 looks pretty good and the red one on eBay has the look of a car that has been in continuous use for a long time.
Given that Austin 7s were cheap cars, I'm not that convinced that panel lines and gaps were concourse standard when new.
About 99.5% of box saloons extant show some what is termed 'door droop'. Most of them are structurally sound.
+1 to that. Mine has the horizontally challenged door problem but it's as solid as a rock. I just call it "patina".
Mine is the same, but the doors still open and shut nicely.
Just to finish this off: thank you for the comments, and particulary the offer to go and see it.
Neighbour has bought the car - he used to own a special in his youth and wants to try an Austin once more.
I look forward to seing it, once I'm back from my boating holiday.
Car type: 1934 RP Saloon
Am I seeing things, or are those sliding windows on the black ‘34 RP?
Well spotted Dugi, unique in an RP, I would say!
