12-07-2022, 07:33 PM
Sidecar tyres are fine. The only issue I have with the Avons is the speed rating wasn’t as fast as my car goes.
What ever tickles your fancy
12-07-2022, 11:48 PM
The Avon Triple Duty Mk.2 Sidecar tyre has the lowest speed rating possible for a road tyre "L" - 75 m.p.h. The Brockey is an "S" - 118 m.p.h. Hence if you have a Seib sidecar on your Black Shadow with original wheels, you'd better be careful which you buy...
Jeff T, Mick, Tony G
assuming the owner bothers with annoyances like a current Warrant of Fitness https://vehicleinspection.nzta.govt.nz/v...and-wheels 8 (d) should cover it, providing the Vehicle Inspector is awake... Interestingly in the corresponding section in the Motorcycle VIRM car tyres are expressly prohibited for motorcycle use (with an exception for side car combinations) |
