fuel pump types interchangeable?
Many thanks for tbe U type fuel pumo information
Jeff
Murmelbar,
As with the 'T' type pump you need to make sure the the operating arm (pump to camshaft) on your 'U' type pump has the correct part number cast into the arm - see my earlier post number 6 in this thread. The correct arm number I quoted was 856955 but that arm number 1524079 is also said to fit.
