28-06-2022, 09:27 PM
(This post was last modified: 28-06-2022, 10:02 PM by Tony Betts.)
Well after 2 years + of struggling to get stock in to sell. Due to covid.
All of a sudden it's all coming in at the same time.
For the last 4 years I've been looking at producing my own cranks, they wont be in large batches. But will be the best quality you can get.
Check the pic below, notice the oil pick ups for the first time are in the correct place. We have also had all cranks xrayed so NO cranks have casting inclusions in them before or after machining. Material spec EN40b nitrided.
I've had a batch of 10 x 1 5/16 splash fed cranks made. But due to weight, (the pick-up is already full). I've only put ONE crank in.
If you are after one for 750 BEAULIEU it would be wise to pre-order, and I'll make sure I have one there for you.
Price is £950.00 each on this batch.
We will have to keep an eye on material and machining cost rises quickly going up for future batches.
Another one that came in today.
NEW rear hub outers.
These were made for a friends race car, material spec en24T. But I'll have to confirm that before the weekend.
Price is £110.00 each or 2 for £200.00
Again, I've only put two in for the weekend. So if you want to make sure you get what you want at 750 beaulieu. It may be wise to pre-order.
Another one in today.
And you can see why the truck is getting heavy.
HADLEY 1 1/2 pressure fed, fully counterbalanced CRANK. Price £1,600 only 3 in stock. Next batch will be 3 to 4 year.
Again I'll put one in for 750 beauleiu, but if you want to make sure you get one. It may be wise to pre -order
The famous hadley 1 1/2 rods came in with the cranks today.
Price £950.00 set with shells.
I only have 4 sets, so First allocation will be given to people buying the counterbalanced cranks.
If you want to buy the crank with rods, the combined price will be £2,400.00
