24-03-2018, 11:55 AM
(24-03-2018, 09:46 AM)Buairidh Dunford Wrote: What do the lower dynamic ratings mean in the application please Tony?
A lower capacity bearing will give a lower calculated nominal design life in revolutions to fatigue failure on a ring or rolling element.
It is used to design any bearing application.
The basic dynamic capacity is the constant load under which the bearing will attain a nominal life of 1 million revolutions. This is only a nominal life- some may fall below it and 50 % will last over 5 times longer.
I quote the figures to indicate why Austin designers would have chosen the Angular Contact Ball front and Roller Bearing rear for the crankshaft - the alternate bearings suggested would lead to a lower bearing life but if this is acceptable then it is alright to substitute.
If you may remember the pinion support bearing went from a roller bearing to a ball bearing and subsequently back to a roller bearing- I would think because of the unacceptable reduced life of the ball bearing.
Tony.
