An "interesting" boat-tail two-seater....
https://www.facebook.com/marketplace/ite...3042100345[/align]  Spot the problems; I'll kick off with a minor one - the cross-head screws holding on the non-original aluminium door capping. I've altered the highlight/shadow balance in some pictures to bring out more detail.
.jpg   280734978_2075772215934558_8523331225564775745_n.jpg (Size: 296.93 KB / Downloads: 1,177)
.jpg   280865835_2075772432601203_4683762898956289441_n.jpg (Size: 197.16 KB / Downloads: 1,193)
.jpg   280110853_2075772459267867_3349523500676224711_n.jpg (Size: 356.72 KB / Downloads: 1,197)
.jpg   280290907_2075772345934545_227527149078354162_n.jpg (Size: 386.46 KB / Downloads: 1,191)
.jpg   280649405_2075772379267875_1246276897635466726_n.jpg (Size: 225.58 KB / Downloads: 1,201)
.jpg   280643672_2075772155934564_8504799545542255166_n.jpg (Size: 299.7 KB / Downloads: 1,208)
.jpg   280905871_2075772355934544_952174374544234955_n.jpg (Size: 415.03 KB / Downloads: 1,208)
.jpg   280744644_2075772335934546_1921538497417924849_n.jpg (Size: 414.55 KB / Downloads: 1,222)
“Canterbury” is in Kent. Is that anywhere near Dover? Is it as close as you can get to Dover due to tailbacks on the A2 and everywhere else in the Garden of England? I am impressed by the use of special machinery that can staple carpet onto steelwork. Maybe it is hydraulic or huge staple press driven by line shafting, perhaps built by AF Craig in Paisley in about 1907. Perhaps not.
(13-05-2022, 09:23 AM)Steve kay Wrote: “Canterbury” is in Kent. Is that anywhere near Dover? Is it as close as you can get to Dover due to tailbacks on the A2 and everywhere else in the Garden of England? I am impressed by the use of special machinery that can staple carpet onto steelwork. Maybe it is hydraulic or huge staple press driven by line shafting, perhaps built by AF Craig in Paisley in about 1907. Perhaps not.
Yes, it's from our man in Dover.
Even the Austin script on the radiator is wonky!
Looks like some/all of a boat tail body, has it been lengthened in the scuttle to fit LWB chassis?
Certainly longer in the scuttle than other high rad boat tails I've seen.
The windscreen is unmolested, and will be unique to the boat tail in terms of width.
I had a '32 box registered in Kent on a 3 + 3. But I think '31 unlikely
"Car Number 25, Original Plate".
That's curious, as number 25 would place it as very early 1929 at the latest, that registration dates from March 1933 - at least twelve months after the last boat-tail was built - and the car displays characteristics mostly relating to late 1931!
There's undoubtedly elements of an original boat-tail somewhere in the car, but champions of originality might well be advised to steer clear; having said that, it might be a worth-while buy at the advertised price, but a personal inspection is probably a necessary precaution!
It's on the Register as a yellow RP.
Seriously, wouldn't trading standards be interested in that description?
decent price I'd say, then body it how you want :-)
Its certainly an attractive 2 seater open car.
Thank you to who ever added the price and description, ooops forgot the inverted commas for “description.” The text immediately identifies the vendor, and as mentioned above the price is almost sensible for a rebody project. But no underbonnet images. HC head, ill fitted SU, Reliant engine? A suitably set up 1172 could produce a good trialling machine. Then again….. back to the workshop.
It says it is a 'very original car' so it must be a very original car, musn't it? [Image: wink.png]
