The problem and potential fixes have been discussed at length on this forum if you do a search. The main thing is to understand what has to be done before you start. Personally I’d take the engine out, remove the camshaft and do it properly. Although it could be done with the engine in the car I’d rather not have the attendant risks, also you have a much better chance of correctly diagnosing the problem with an engine in pieces.
Hi
I agree fully with Alan.
Camshaft location and end float are so often overlooked and not done correctly, the other thing besides this and timing gear lash which often causes knocking is dynamo end float.....there should be none. My personal preference to improving the camshaft location is to the thread the bush and use a stud as the Mag engines had, add Dowty washer under the nut ..... no leaks and a very secure bush
I have gone into the bush from the side of the case with a secondary bsf set bolt tapped into the brass camshaft bush, loctite and Dowty washer used.
Camshaft end float must be controlled to a minimum to prevent the big end from hitting a lobe.
Especially if you have a high lift cam and Phoenix rods. Don’t ask me how I know that.
Odd really as the mag engines had one of the dynamo housing studs threaded into the front bush,exactly as this mod.
