Car type: Ruby mk 2
This carries on from the original oil leak post.
Both securing studs have broken on the radiator that is one leaves a hole the other is loose
Not sure how to proceed
I will try to show a photograph in the morning
Sorry if this is not clear hope the photo will help
The radiator on my special just sits on a couple of brackets I made, with a bit of leather between to stop wear.
The hoses and the radiator's own weight keep it in place, have done for years.
Car type: Ruby mk 2
Thanks Gents
Love the turned brass rod
Shame there is no decent radius at the transition of base to stud ?????
I'd give it a month before it shears !!!!
Car type: Special 1930 chassis
Ilmoro you're on a winner if they stay on your kitchen table for a month :-)
Hi
I have successfully done this repair on one side of a radiator. I made up a threaded metal "penny on a stick". I have plenty of soft soldering experience, but not the many years needed to attempt radiator work. Instead I attached the fixing to the radiator with JB-weld metal loaded epoxy. The penny part had a series of small "colander" holes added, to improve its grip on the epoxy. The tank was thoroughly wire brushed and cleaned, and a screwdriver used through the epoxy to scrape it whilst the epoxy was still fluid.
I believe that originally the studs were fixed using coil springs, washers and locknuts, which is why they are quite long. I retained this setup, but with nylocs. You only need enough spring tension to prevent the radiator jumping up on a bumpy road, i.e. not much. In this way any misalignment may be accommodated without undue strain. I added a thin soft rubber pad between tank and support bracket for good measure.
No problems after more than 10 years motoring.
