18-02-2022, 12:05 PM
(This post was last modified: 18-02-2022, 12:06 PM by Tony Griffiths.)
Put up by Helmut on Facebook:
Austrialian-bodied "Doctor's Coupe Convertible"?
18-02-2022, 06:13 PM
Sweet
18-02-2022, 06:35 PM
I'll second that.
It would be nice to see how it looks with the hood down. May be awkward on that shape of boot, unless removed altogether. Tony.
18-02-2022, 08:29 PM
This is a Holden-bodied version, similar but not identical:
18-02-2022, 09:06 PM
thanks mike,
that makes a bit more sense. the main hoop, folds forward before folding back. which probably shortens the length of the hood by 6 or 7 inches. must admit it would have looked funny if it extended another 7 inches. if you see what i mean. tony.
18-02-2022, 09:56 PM
19-02-2022, 02:07 AM
(This post was last modified: 19-02-2022, 10:07 PM by Tony Press.)
As far as I know all these Coupes were built by Holden Motor Body Works in Adelaide- the first picture shows an early headlamp on scuttle model, the second a later 1929 front headlamp model.
19-02-2022, 09:12 AM
Hi Tony, I'm pretty sure the second illustration is not of a 1929 version, unless they re-bodied earlier cars. This car has 6" brakes, early steering wheel and small headlamps suggesting 1926 at the latest.
19-02-2022, 06:11 PM
Could someone enlighten me as to the origin of the name "Doctor's Coupé" please? Which (or Witch?) Doctor? A particular Dr. or just any old GP?
Or was it so they could avoid/encourage passenger(s)? Where did the little black bag go?
19-02-2022, 10:15 PM
(This post was last modified: 19-02-2022, 10:42 PM by Tony Press.)
You are right of course- I didn't look properly- and it has a vertical one piece screen unlike most Holden bodied Chummys ?
I know that at least two 1928 Holden bodied Chummys were fitted with a conversion to front headlamps with a locally? made pair of brackets, leaving the screen lamp mounts on the windscreen brackets. |
