11-02-2022, 09:07 AM
Fan pulley
11-02-2022, 09:12 AM
That is an early coil fan pulley mounted to a magneto fan pulley bracket.
11-02-2022, 09:31 AM
Blast ! I'll have to find the correct one.
Thanks
11-02-2022, 09:33 AM
(This post was last modified: 11-02-2022, 09:35 AM by Ruairidh Dunford.)
You and Stephen need to swap.
BTW - the steel (?) section of your pulley itself is unusual, most likely an older repair.
Distance between us may be an issue !
(11-02-2022, 08:49 AM)Ruairidh Dunford Wrote: That is a top pulley from a magneto engine. Hi Ruairidh I knew it was something to do with mag engines. I had just this problem a few years back but couldn’t remember if changing the belt or the pulley solved it. ![]() Cheers Howard
11-02-2022, 09:37 AM
The pulley is bronze probably locally made years ago. There seem to be quite a few Bronze items locally, I have a steering box and also water outlets.
11-02-2022, 02:19 PM
(This post was last modified: 11-02-2022, 02:19 PM by Steve Bryant.)
You might need to check the distance between it's mounting and radiator core as one will be about 3/4" different in length dependent on the car or it's from a 3 sp or 4 sp crankcase.
11-02-2022, 07:27 PM
Hi Stephen,
I can do a dimensioned CAD drawing if you want. Marcus |
