Which Newman cam do you have? Years ago I had a reground race cam from them. You could hardly feel any compression if you wound it over by hand, but it revved it’s little socks off. If your cam has a lot of overlap it could be like that.
I would have thought if pistons are metric they would be directional.
These are the slipper pistons, I took over from quarry engineering.
Some of the earlier rings the word TOP was there but not that obvious.
Tony.
[attachment=16715]
HI DAVID,
A Couple of THINGS, how did you put a highly tuned Engine together with out Knowing the volume of the head.
the oil on the top of the pistons could be bores being glazed so you will need to check bore size just below where the top ring comes to .
You will also have to pull engine out to rectify the loose flywheel because if you do manage to get it to rev you are very likely to end up with a very expensive repair Bill.
just take your time and check every thing from scratch.
All the Best
COLIN
NZ
