Can anyone confirm whether there's a stepped bolt that is used at the junction between the radiator, cowl and bonnet stay on the jewel cars? If so, can anyone post a picture of the bolt?
Asking for a friend!
11-01-2022, 11:11 PM
(This post was last modified: 12-01-2022, 06:01 PM by Colin Morgan.)
Yes, there is a stepped bolt on mine - but I don't have a picture, sorry - or even a description, and it is v. cold and dark out there at the moment.
Correction: Having had a closer look at the item in question, it is comprised of four different sections in one - at the bottom, a threaded portion to connect to the radiator, then a short length with a larger hexagonal section so it can be held for tightening of similar proportions to a nut, then above that a cylindrical portion before a second threaded bit that allows the stay to be attached - so a bespoke item for which a drawing would be useful.
Thanks Colin. It's not that pleasant here either. It would be very interesting to see what it looks like, but I am happy to wait until the summer if necessary. The bolt and washers in mine are perfectly fine...
But I was asking for a friend...
Thank you Colin, that does look interesting... does it have two different threads or nuts top and bottom?
Having looked at the threads, rather than the bottom nut size - they are both 5/16"BSF top and bottom, with the intermediate hexagon being 3/8"BSF (or 5/16"BSW if you prefer).
