wiper arm dimentions
Will anyone tell me how to make the small flat metal piece of the wiper arm, I would love some pictures and measured dimensions. The piece I am looking for is on the right side on the 1st page.
http://www.da7c.co.uk/History%20Section/...%2030G.pdf
(10-01-2022, 05:58 AM)Vancevr Wrote: Will anyone tell me how to make the small flat metal piece of the wiper arm, I would love some pictures and measured dimensions. The piece I am looking for is on the right side on the 1st page.
You could scale the drawing so the shaft is 3/16 inch, print it out and then use it as a pattern for piercing from 18 swg steel sheet.
You'll need a piercing saw and fine blades.  https://www.hswalsh.com/product/eclipse-...ixed-ts125
Thank you so much, I will give that a try
