If it's any help Ivor, mine came from the Seven Workshop a long time ago and they're glued on.
Thanks Bruce, yes mine are from the Seven Workshop and glued, but the strength in the running boards themselves comes from the bolts to the wings and of course the screws along the upstand which screws to the sill...I have all the holes, but don’t know what should be in ‘em!.
Ah, I guess mine are bespoke because they bolt to the sills from underneath. Perhaps the sills are bespoke too...
Car type: 1932 4-seat Tourer, 1925 Pram Hood Chummy
There should be 4 narrow strips of wood (ash) on the inside of each of the two sills. These are what the vertical sections of the running boards and also the inner (carpet covered) metal valances are fixed to. Original fasteners were 3/16" BSF round head steel machine screws with washers, the nuts being recessed into the wood strips. I don't think A7 running boards 1932-1934 were ever intended to take the weight of anything more than a child or maybe a young lady of average weight (apparently 8st pre-1950!).
Ivor,
We're getting into "rivet counting" here, but originally there were three screws along the top edge and 4 along the bottom. You have an extra hole just under the wheel of the motif.
Taking most of any load are the 1/4" hex head bolts fastening the two end flanges of each running board directly to both the rear wing and the flange of the front wing (two at each end, 8 in all).
As you say, it's a pretty sturdy job, but you wouldn't want chaps weighing 16 stone regularly standing on them!
Thanks Mick, I’m no rivet counter, but I like to get things as close to original as possible.
I shall follow your guidance to the letter!
