Car type: 1929 austin 7 chummy AD
Should be and easy question to answer but what grease should I put in a 29' speedometer to hold the ball bearings in place and keep it lubed up? Working on getting back to working order. Also any tips on the subject.
Vancevr, what we use in our shop is called "Assembly Grease". It is blue in colour and designed to hold bits in place for assembly such as what you are trying to do. It can be usually purchased in a small plastic tub slightly smaller than a margarine tub. Pep Boys or a place like NAPA should have it.
Hope this is of some help.
Stephen
Thanks I will try one of those
